Sydney99
Android Expert
PhilZ 5.14.5 is up
Cue Ironass, the changelog specialist......
Along with a hefty dose of sarcasm, no doubt...
PhilZ 5.14.5 is up
PhilZ 5.14.5 is up
Without question.
I once asked him if he sees himself as a sarcastic person, to which he replied "no"
sarcastique, aucun moyen!![]()
Anybody updated to 5.14.9 yet? I've downloaded the file twice, but when tryinig to flash, I keep getting an error:
"Can't open /external_sd/philz_touch_5.14.9-i9505.zip
(bad)
Installation aborted"
Is it me (I wouldn't be surprised if it is...) or are any of you also having this? I've no problems reading or writing other files to my SD card.
No, I'm not using Odin, I'm just using Philz own recovery to update it. I've got 5.11.2 running and I just thought I'd update it to the latest version.Are you trying to flash a CWM flashable .zip file using Odin?
PhilZ Recovery 5.17.6 is up!
"The final stable is here
The menus are changed because of the new vold code in cm-10.2: you can hotplug USB key
Now, backup of 3.5 Gb to internal storage, all stat options enabled, takes around 3 mn (same speed as stock CWM)
Backup to exfat external storage of same data is extremely fast too, around 10mn and maybe less if you have a faster card than my old one
Do not forget to enable all progress stats again in Misc Nandrodi Settings. I tested for you: speed change is about a few seconds only now with or without them
Big thanks to @wanam for providing latest kernel to fit this
Also, @xiaolu for his vold changes to support exfat through ko modules"
Download for i9505, v5.17.6.
Download for i9500, v5.15.0
Sources, here and here.
UPDATE
Another, "No go", for me, even after changing my Storage in Advanced. Back to v5.15.8.
Hmm you haven't swapped phones with Syd have you, just a thought.
