Your post are getting smaller and smaller!![]()
6.04.0 are now up!
On the subject of grammer, shouldn't that read... "6.04.0 is now up!"? Since only the i9505 version has changed.
Look old boy... as it's near Christmas, I've sent you a template of the PhilZ update posts that I use, to make things easier for you. Nothing could be simpler or more foolproof. Just try using it.![]()
Why do you think I put a smiley at the end of the post?
Do catch up butty!
You utter, cantankerous, contrary, Celtic, plonker! :banghead::banghead::banghead:
I sent you the template so that all you had to do was fill in the blanks and you could have a legible update post in two shakes of a lambs tail!
(Possibly not the best expression to use in conjunction with a Welshman)
Lmao :-D
Well here is the the best laugh yet since their Double Act Began.
Just a small note on OBackup old fella.
I do not believe it is currently being developed by the author, and has not been updated since July.
I use Online Nandroid Backup which is much more current
I'm sure Syd told me to use OBackup. :listen:
OK... Online Backup in conjunction with Nandroid Manager, it is then. Cheers old boy! :cheers:
(Post #170, amended)
Hey!, maybe you have heard of this before...I have searched and came up empty handed. I'm using philz on my samsung gtab 3 sm t310 (the newest I'm guessing as its based on cwm 6.0.4.5 and all WAS well until i went to try to restore a backup from sdcard.I'm sure Syd told me to use OBackup. :listen:
