Ok, so I wanted to install the jellybeer ROM on my S3 and I've never done this before, I followed the instructions on a website and got to this point:
The next steps were to format then go in 'Advanced Menu' and stuff like that but I don't have any advanced menu. It says Android system recovery <3e>.
I've already formatted it and I have no idea how to install the ROM... Have I bricked my phone?
Cheers
1. Make a backup of all your personal data, contacts, APN settings etc, as installation of a Custom ROM will involve wiping your device and settings. Stuff on your internal SD card like your photos, videos and music wont be affected.
2. Download the latest version of the Jellybeer ROM from the original XDA thread. No need to download and flash Gapps separately as they are included in the ROM
3. Now connect your Galaxy S3 to you PC and transfer the downloaded ROM zip file to the internal SDcard on the phone
4. Disconnect the phone from PC and turn it off completely.
5.Reboot the S3 into recovery. To do so, Press ‘volume up’ + ‘home’ + ‘power’ buttons at the same time and release them when you see the Samsung logo. Once in CWM use the volume buttons to navigate through options and the ‘power’ button to select them
Cheers
