sntaylor
Android Expert
Well guys, I had tried this Rom out a few weeks ago and I wasn't hugely impressed due to little bits force closing and then just trying to get used to cm10.2 again as I hadn't used cyanogenmod for ages.
I decided the other day(Friday) toRestore my previous back up, it then asked me to update ota, so I eventually did and I'll tell you the latest update 4.3(pro bam not android, though it is based on 4.3 ;-) ) is a big improvement, I am missing a few features like Nfc screen off and gesture to answer call(great if out working on motorbike with greasy hands!) And 3 minute mod However seems to be almost on a par with any stock tw Rom I've tried.
Tweaks and settings available are numerous, and for a novice flasher in particular very intimidating(I only tried on s2 briefly for this reason) however once you get your mind around then it's great.
If you don't know yet, this Rom is based on cm10.2, aokp(based on cm10.2 with tweaks) and paranoid android(also cm base). Because it's android 4.3 you now have access to block permissions of individual apps.
http://forum.xda-developers.com/showthread.php?t=2377129
Worth a go if you like stock android and features, and can go without some of the Samsung features
