dalmanights
1. In November 2014 I purchased, a Samsung Note 3 N9005 having H3G UK rom in UK that I use presently in Asia. This snapdragon model came with Jellybean and it was my first Android phone as I used windows phone earlier.
2. I did not know head of tell of Android OS and as I started using this complex phone, in a day or two it showed a pop up that said a 2 GB update was downloaded automatically (auto update was checked) and it updated the my phone from Jellybean to 4.4.2 kitkat.
3. The phone showed the following info :
PDA/ AP (firmware build version) : N9005XXUGNH1
phone/MODEM /CP (baseband or modem version) : N9005XXUGNH1
CSC(Consumer Software Customization) : N9005H3GGNI1
Build number as : KOT49H.N9005XXUGNH1
4. I tried Kingo root to root the phone but it failed and nothing was changed as shown below:
ODIN MODE
PRODUCT NAME : sm-n9005
CURRENT BINARY: SAMSUNG OFFICIAL
SYSTEM STATUS : OFFICIAL
REACTIVATION LOCK (KK) : OFF
KNOX KERNEL LOCK : 0X0
KNOX WARRANTY VOID : 0X0
QUALCOMM SECUREBOOT : ENABLE (CSB)
AP SWREV : S2, T2, A2, A3, P3
WRITE PROTECTION :ENABLE
UDC START
5. Then I tried Towelroot and it succeeded in rooting without any Knox flag and all remained as shown above. I tested it with rootchecker and Supersu and phone was shown as rooted. Then I connect the phone to Kies3 and it refused to connect to the phone or even regognize it. Therefore, I went ahead and with Supersu to remove the root fully. In the mean while I found that the phone started showing a triangle and security notice that said - Unauthorized actions have been detected.
6. Then I tried to start Samsung knox which was perfectly working before rooting. The Knox tried starting with a brown screen for a second and just came out of it without actually starting it and with no warning.
7. All things like wifi bluetooth etc except the working of Knox, were fully functioning and Knox counter was 0x0 with official ROM intact. Except for the security warning all things were perfectly functioning.
8. Recently (27 March 2015) I got another popup saying Lollipop update is available for download and it downloaded it successfully and started the update. The update process stopped abruptly at about 25 percent and gave an error message and restarted the phone with the 4.4.2 again. The original rom, knox is still intact but rootchecker says root having errors and phone is not rooted. However now my wifi and bluetooth stopped fully and just could not be started through the settings.
9. My question is, can I flash another stock UK rom or the same H3G rom 4.4.2 through Odin 3.09 or 3.07 without knocking off the official status of rom and Knox 0x0 status?
10. If I flash stock rom Vanilla (BTU) UK, what would possibly happen? Alternatively, If I flash the exactly the same 4.4.2 H3G ROM UK that is presently on my phone once again using ODIN 3.07 or 3.09, will it bring the system to original status (factory) so that I can officially flash the Lollipop that is available for H3G UK phones? Or the knox is damaged forever even if the Knox counter is still 0X0?
11. Any better alternatives open to me? I have to do something as my wifi and bluetooth are both dead but phone is functioning other wise for calls and messages. Is Knox dead forever even if the flag says 0X0 and rom as official?
Note: I am familiar with the procedure of using ODIN for flashing.
I would appreciate all your help to get over this mess.
ODIN MODE
UDC START
