Root [International] Rooting discussion for 4.4 (kit kat)
rumrunner will give you s off,and id highly recomend to do that prior to 4.4,in case exploits are patched.
rumrunner does NOT install a custom recovery by default,so becoming s off does NOT mean that you can not OTA natuarally to 4.4 when(if ;) ) it hits
as long as youre s off,rooting will be easy :)
of course,once youre s off,you can install a recovery and try one of the many 4.4 roms out there,wich are devoid of big reds bloat. there is no real benefit to waiting,IMO
http://rumrunner.us/
I was under the impression that rumrunner did not work for Android 4.3 on Verizon and that I would have to wait for Firewater?
EDIT: Firewater should be coming out soon and I will NOT be accepting the 4.4 OTA in the meantime as i'm sure it will kill any chance I have of unlocking the bootloader. Once I get it unlocked and rooted i'll just install a 4.4 ROM. Most likely Cyanogenmod or Viper ROM.
I thot rumrunner worked with 4.3,but not having vzw any longer I haven't followed it that closely. At any rate,firewater is out: http://firewater-soff.com/
I'm itching to try it out on something,lol
