Root [International] Titanium Backup Pro problem
Toosploos
As of recently Titanium Backup Pro (one of the few apps I bought legally through the Playstore) has been having some hickups on my S3. Even though the unlock key for the pro version has been installed, TBP doesn't see the license.
I use the same app bought with the same google ID on my other device and everything- including the pro functions - is running smooth there.
Could this be an S3 problem? Anyone else been having issues? TB has not been responsive to my questions yet, so I thought I'd give it a shot here.
Some additional info:
- I'm rooted (obviously)
- Tried un- and re-installing TB and the Pro Key. Both are installed properly and are showing up in the applications manager
- Used a root explorer to search for the TitaniumBackup_License.txt and nothing came up.
Thanks in advance.
TP
Its Karma mate :P
JK but i used to only use free or pirated apps until PowerAmp where none of the pirated keys would work so i bought it but continued using pirated apps.
Then i got a nasty virus from one and wasnt prepared/backed up for it so i only use official apps now (NEVER thought id hear myself say that but its a good lesson for new users.. viruses are very real!)
Sorry im not helping your problem man but just felt i should comment :)
Ive no idea what the problem is tbh sorry. As far as i know, Titanium has no problems on the s3.
Good luck :beer:
when u start TB does it give you a message regarding play store id? whenever i installed TB it always gave me a message regarding play store id and when i click on use old id it would restart and everything worked great. You can try completely removing TB and the pro key and install it again or try contacting the developer of TB and ask him.
Thanks for the reply. I do not get that message and in the settings I can see that TB is linked to the right ID. Tried un-and reinstalling, clearing cache, deleting the Keramidas data folder - so far no luck.
I contacted the dev, see what happens.
For anyone interested: turns out that the Chelpus Google Play hack can cause problems with license verifications. I played with that app, decided not to use it, but by then the original Play App had been so tinkered with that my phone wouldn't recognize certain pro licenses. I flashed another rom (using Carbon to back up apps and data - great app by the way!) and now all is good.
Hi, I just rooted my s3 and when I tried to put my old TB license on it, things went a bit sideways. For one thing I have a mac and the Android File Transfer is different than native file system, in that it was hard to just drag and drop the license txt. After numerous attempts (drag drop, delete, ...) I was finally able to just drag and drop without it going into a folder, and it is like oid times. The file transfer is a bit squirrelly. If you can't just drag and drop, maybe try dropbox.
HTH
