OK, took the leap to OmniROM, but getting an error when trying to install. I have installed TWRP 2.6.3.0, booted into TWRP, selected Wipe and slider for factory reset
Then select Install, and selected the Omnirom zip file (omni-4.4.2-20140113-i9300-nightly.zip) then swipe to confirm flash
It checks the MD5, it then says "formatting /system", then "extracting /system" then it says
set_metadata_recursive: some changes failed
E: error executing updater binary in zip '/external .......
Error flashing zip '/external_sd/ROM's/omni-4.4.2 ...........
Updating partition details .......
and then it shows a red failed message
If I reboot, I just go back to TWRP .. where I can restore my NAND
What is wrong here?
What is wrong here?
) ... how do you set a lock screen wallpaper in OmniROM. I can see how to set the wallpaper, but doesn't seem to be an option for setting lock screen?
