sntaylor
Android Expert
Hi hawker, better give you this before ir....... Oh, OK, had a few too many drinks???GravityBox v2.9.4 released.
Changelog 2.9.4 - 25/01/2014
- Expanded desktop revised:
--- Immersive mode now fully working without the need of reentering app
--- Immersive navbars now re-hides itself correctly in apps where it previously didn't
--- Added new mode: Immersive status bar - keeps navbar in normal mode and statusbar in immersive mode
- Smart Radio reworked from scratch - based on connectivity manager events
--- Option to force power saving mode when screen turns off
--- Option to ignore switching to normal mode after screen turns on until device is unlocked
--- Option to set delay of network mode change to filter out temporary connection state changes
- Lockscreen tweaks:
--- Added option for custom carrier text (default/custom/empty: when space entered as value)
--- Fixed crop size when cropping image for custom lockscreen background
--- Last screen:
------- preserves original orientation regardless of lockscreen orientation (won't rotate with lockscreen)
------- fixed orientation for devices having flipped screen (thanks to superdragonpt for hints)
--- Added option for specifying blur effect intensity
- QuickSettings tiles:
--- Sync tile: added long-press action to open sync settings
--- Network mode tile: added long-press action to open mobile network settings
- Pie Controls: Implemented support for handling long-press on pie keys
- Phone tweaks
--- Added answer/dismiss call actions to non-intrusive incoming call notification
--- Unblocked SIP calls over mobile network
- Power tweaks: Added option for battery charged sound
- Key actions and GB Actions:
--- Added action for taking screenshot
--- Added action for showing volume panel
- Display tweaks:
--- Added option for controlling pulse notification light delay (frequency)
--- Added option for enabling/disabling translucent decors (thanks to scaryuncledevin)
- Misc tweaks:
--- Added setting to change tap vs long-press modes of clearing recent tasks (thanks to scaryuncledevin)
--- Extended option for controlling overflow menu button
- Notification drawer style: Added option for custom carrier text
- Added option to disable power menu on lockscreen
- Added delay to screenshot action
- Hide 'Torch auto off' option if device has no flash (thanks to bgcngm)
- Fixed data traffic monitor not showing values on some devices (thanks to PeterCxy)
- Updated Portuguese (PT) translation (thanks to bgcngm)
- Updated Spanish translations (thanks to jvbferrer)
- Updated Polish translations (thanks to xtrem007)
- Updated Chinese (Simplified) translations (thanks to liveasx)
- Updated Italian translations (thanks to pesa1234, valerioscifoni)
- Updated Japanese translations (thanks to WedyDQ10)
- Updated Russian translations (thanks to gaich)
- Updated French translation (thanks to ch-vox)
- Updated Chinese (Traditional) translations (thanks to Eric850130)
- Updated Slovak and Czech translations
Download available http://dl.xposed.info/latest.apk
