Root [International] wifi, cam wont work after flashing custom rom. Galaxy s3
cagedjam
I have a galaxy s3 international version. I tried installing a couple of roms including cm, supernexus and pA but after flashing my wifi an camera wont work in any of the roms. Anyone has any fix to this ? Help would be really appreciated
Had issues with camera app in CM10, but no other ROM and was running PA for a while.
Make sure you do a complete factory reset; wipe Dalvik cache and try the latest CM ROM / Or what ever you choose and see if that helps
Should'nt need to flash the camera or radio separately but that maybe the fix.
What are the exact versions you are trying to flash; maybe these are known issues?
I followed all the steps, cleared dalvik cache and the other steps that are given with the rom. Still no luck. Im on stock 4.1.2 with root. Do I need to flash bandbase when I change my rom ? And I tried cm 10.1
Not to sound like a prick but it is definitely CM 10.1?
Most of the latest 4.4 ROMs (CM 11) are having problems with the camera.
I have the same problem with supernexus 3.0. Cam and wifi wont work.even did everything from scratch after flashing stock rom
