Help Internet problem
clutton86
Hi guys here's the problem where I live has really slow internet only gprs however on the last update I noticed that when you go to network operators you can choose 2g or 3g when I choose 3g it says 'your Sim card does not support this network type' I can connect to 3g and hsdpa in other places just wondering if anybody knows why I can't do it at home i'm on o2 in the UK if that helps
Thanks
Might simply be that your house doesn't have good 3G coverage. I know I can't get a 3G signal for carp when I'm at home... I've never been told my sim doesn't support 3G though.
Unfortunately I am not familiar with this particular network, however this is not normal behavior for our handsets unless you have a 2G only SIM. With this being the case I would advise just checking with your network to see if they are willing to look into a SIM replacement for you.
