Okay, i appear to be stuck on the bright HTC Logo. Gonna try to reflash incase something went wrong in the process.
Edit: okay yeah, it's not working for me. Can't get past the HTC Logo.
did you flash the kernel with fastboot?
Ah, it appears i didn't flash it correctly. I did it again and it successfully booted into the CyanogenMod boot logo. Thanks for your help from a noob like me!did you flash the kernel with fastboot?
I have about 700MB of storage available (compared to the ~200mb that is quickly eaten up by VM's livefeed and google's updates.)![]()
Thats right folks you heard it, rbheromax, kalisto2002 and I have been working on Cyanogenmod 11 for the sprint and cricket variants. It is a definite Alpha as of right now, I felt that we had enough working to release a version for testing.
Whats working so far:
Cricket:
RIL (data/4G LTE & Voice services)
MMS (texting and Multimedia Work)
Audio (all Audio working)
Sensors ( G Sensor/ Proximity Sensor/ Light Sensor all work)
Display ( Ofc Display works)
Mic ( Voice Recording/In call mic all work)
Wifi ( Yes finally fixed wifi Thank you rbheromax)
Bluetooth ( Bluetooth works and pairs)
Sprint:
Not sure (we need a sprint/VM/Boost activated tester)
Not working:
Cricket/Sprint
Camera (Front and rear cameras not working
So that’s the run down, as you can see we need a tester on a sprint carrier to test the rom and see what works and doesn’t.
PS. rbheromax was gracious enough to port the MSM8974 kernel to our device. CM11 will not use a stock based kernel. This means we will have the most recent updates for our kernel from cyanogenmod themselves! Please be sure to show rbheromax your gratitude!
Project Information
Unofficial Cyanogenmod 11, ROM for the HTC Desire 510
Contributors
shinru2004, rbheromax, kalisto2002
Thanks to Google for Android, And Cyanogenmod for their sources
Source Code: http://www.github.com/shinru2004
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.4.x
ROM Firmware Required: none
Based On: CyanogenMod
Version Information
Status: Alpha
Created 2014-12-24
Last Updated 2014-12-23
I can't Flashing this file With TWRP 2.8.1.0 "Error flashing zip"What service provider are you on?Everything is great... Didbclean install and fast booted kernel,.one problem, WiFi wont connect.. It turns on.. After entering WiFi pass code it says " obtaining IP address " then "connect ing". Then it just does not connect. Any help??
This ROM should work on VM USA; i have it installed currently and am able to use all of my phone except the cameras (Which I hardly ever use, so it's not a big sacrifice for me at all. ).I certainly hope everyone didnt give up on this ROM, because this Cyanogen based rom was looking promising....
But I am on VM USA and this Rom was not usable for me (almost everything worked-except for phone service)
But until something develops, do a search for RaptorRom v1.1 (version 1.2) its a probably one of the best out there for the VM USA users... (if you are one)
good luck.
If someone with boost variant can do
adb shell
getprop
find the line named
ro.boot.mid
post the result here, only the virgin mobile variant has been added to the ril
In addition I need a copy of the Virgin mobile and Boost mobile build.prop files
Cricket:
Sprint:
Not working:
Cricket/Sprint
Project Information
Contributors
Version Information
Status: Alpha
Created 2014-12-24
Cricket:
Sprint:
Not working:
Cricket/Sprint
Project Information
Contributors
Version Information
Status: Alpha
Created 2014-12-24
