I have noticed this for a while now and my friend mentioned it as well. When searching around we weer unable to find a resolution to fix it.
When you save numbers to your contacts, Android automatically adds spaces in the phone number. Between area code and number then periodically to make it clearer to read. This is great.
However, if you I try to text someone from my contacts I keep getting an invalid recipient error. After closing the error button, the number is shown in the recipient field. I then have to manually delete the spaces in the number in the text message recipient field for it to accept it.
Is there any way to either save contacts without the auto formatted spaces, or to fix the issues from the messenger side?
