Inverted playstore (flashable)
exgenmeikoj
Not my work, just reposting
Credits
-Sniper
-Team Baked
100% to both
Inverted Play Store
MD5: 38dd0739e2c39b6512afffd70de56b2d
Instructions:
Download
Nand if you wish
Flash from recovery
Reboot
Confirmed to work with all devices
DS
Seen this and thought I share
Link fixed
(I have tested this link on 7/03/2013 working as of now)
(Dragonslayer95 apologies for the broken link and has fixed it) enjoy (;
This apk is a jb 4.2.1 gapp... Works well with jb but Might not work so well on any rom running ics or lower
Inverted Playstore link doesn't work.
Did you check this before posting?
Yes I checked this link its in the epic 4g touch forum all I did was repost it here for thoeses who dont know any problems of the link should be referred to the post there
The link does not work. Would you like me to fix it for you so others can click on it?
Just checked this now and im redownloading it again the link works for me perfectly fine.
As I stated in the op dargonslayer has fixed it all I did was repost the same one he fixed it with. If it s not working for you ill make another mirror or you can go to his post in the epic 4g touch.
Again I just checked the link its working fine
-edited- my apologies I did not read your question correctly if I missed a step on posting the link plz do fix for others to to enjoy this master work of art and thank you (;
