Accessories Invisishield @ BB - defective
If you bought an Invisishield screen protector at Best Buy, you may not have heard that they were pulled off the shelves for being defective. Apparently the solution used to bind the plastic to the screen was causing some noticeable blurriness.
I was told at my local BB that if you bought one before they were pulled, you will be given a replacement for free. BB here says no receipt should be needed if you know about the recall. They weren't sure when the new ones were coming in (I will be checking and will try to update this thread when my store gets em) but make sure you take advantage of a free replacement, even if you aren't seeing the blurriness they are talking about!
CHEERS :p
I complained about my issue a day after my install. there were thin rainbow lines on mine. almost had to knock out the b.b guy till his manager stepped in and refunded me
