IPhone 6s+ vs a few androids
iDapzZ
OK so I always have this dilemma of which phone to get next but atm it is worse than ever as I'm going to buy it outright...
I'm struggling between iPhone 6s+, z5 premium, note 5 or nexus 6p.
I use alot if streaming and screen mirroring which I know I couldn't do on the iPhone.
But I also want to play mobile gaming which I'm under the impression iPhone is more capable.
Thank you in advance
I can help narrow down your choices.
The Sony won't be available for at least another month, with current ETA being mid-November, while the Note 5 isn't being marketed in Europe at all. If you buy that you'll have to be very careful that Samsung UK will honour whatever warranty comes with your handset.
So right now your choice is between the Apple and the Nexus, and as this is an Android community the decision should be obvious. :)
I think it's fairly obvious if you are buying outright and on a budget, iPhone is out ;)
Is the iPhone supposed to be better for gaming? Isn't the Nexus Octa-core, and Z5 quad-core, with Iphone being dual, and both Androids extra GB more RAM?
Thank you for moving it to the right place :)
Didn't realise the note 5 wasn't available here :( would be the z5 premium, nexus or edge plus then.
There's more to it than just specs on paper its how it uses that power and of course graphics cards also come into play. I'm not saying apple is better before anyone thinks that just saying there's more to it.
And that's what brings me here asking the question the budgets not the problem as I plan on keeping it a year and trading up as I usually swap and change A LOT! I'm currently using a nexus 5
The Z5 uses the same SD810 SOC as the 6P.
Then the choice has to be between the Android handsets.
If the games you want to play aren't available for Android, or don't perform, then the choice has to be iPhone.
