Help iPhone not recieving mms from Incredible
I have been having troubles sending picture messages (mms) to people's phones. After some work, i have narrowed it down to only having problems sending mms to iPhone's.
Does anyone else have this problem?
I talked to technical support and they told me it was on at&t's side as it shows in the verizon system that it was sent.
Let me know what you guys have seen...
Thanks
Sorry it didn't work. I had been dealing with this for a few days and it was a HUGE annoyance! It has to do with the size of the photo that Att restricts, or something along those lines. The Incredible takes a 8mp photo, and yes i know it automatically shrinks it, but something still causes it to not work.
Make sure you add the caption because this solved my days of FRUSTRATION and I now am able to successfully send 100% of the time. I know u said it didn't work but try it again and see what happens. Also try taking a smaller photo, which to me is dumb but worth a try.
