iphone to android
I work for att and i have customers who are coming from iphone to android! we are running into the issue of syncing contacts from iphone/itunes to the android phones (in this case the htc inspire) does anyone have a solution for this issue? thanks much:D
Do you have the option to export the contacts in itunes as a csv file? If you can, export, then upload the csv to the gmail account associated with the android handset. Then sync your gmail account and the contacts should appear on your inspire(s).
Not sure about tunes etc, I'll have a look and see if I can find any guides.
