Does anyone else here have an unstable admire? For example, many of my apps are crashing... Is this something with the admire or the android operating system?
also, how do I reformat my admire, and start all over again?
Guessing it because of your effort to flash it to pageplus, without having the background to do so.
Nope, steady as a rock.
If you have rooted there is no stock reflash.
If not rooted then synch contacts and go to settings>privacy > factory reset
Or reboot into recovery and choose factory reset
There is no flash to stock so if you root you may have messed in a system file and caused your issues. In that case you need to figure out what you did and fix it.
When a phone isn't rooted there is far less of a chance of a system file malfunctiion and a greater chance of symptoms being from malwear or corrupt apps. Wiping the altered data with a factory reset can six them sometimes. Just remember to synch or backup your contacts.
