If you have wifi enabled your not using 3G so you aren't using the unlimited data while connected over wifi.
If you have Wifi enabled(and are connected to it) you will be using your Wifi instead of your data plan, it's always like that if your connected via Wifi, when you aren't using Wifi your using your data plan.So simply by having wi-fi enabled means that I'm using that (by default) over the data plan?
PS Thanks for your help!
Np![]()
