Jaffa Android Expert Jun 6, 2011 #1 visionary didn't work Build:1.84.61.2 CL33804 Software: 1.84.61.2 Kernal: 2.6.32.21-g46445e7 I not bothered about custom ROMS just want to remove bloatware downgrading and then installing a custom seems excessive. I just need SU perms Thanks in advance
El Presidente Beware The Milky Pirate! VIP Member Jun 6, 2011 #2 Which Android version does that relate to? 2.2.1?
F freestyle_gus Newbie Jun 6, 2011 #3 Jaffa said: visionary didn't work Build:1.84.61.2 CL33804 Software: 1.84.61.2 Kernal: 2.6.32.21-g46445e7 I not bothered about custom ROMS just want to remove bloatware downgrading and then installing a custom seems excessive. I just need SU perms Thanks in advance Click to expand... Yes, I'm afraid a Goldcard is the only way. You need to downgrade to 1.32 and then Visionary will work. I know it's a pain, as far as I'm aware there is no way to get su permissions on 1.72 or 1.84 any other way.
Jaffa Android Expert Jun 6, 2011 #4 El Presidente said: Which Android version does that relate to? 2.2.1? Click to expand... Yes
El Presidente Beware The Milky Pirate! VIP Member Jun 6, 2011 #5 Jaffa said: Yes Click to expand... See gus's post then. I wasn't sure what Orange software correlated to each Android version.
