I rooted my DroidX for more battery efficiency. Rooting allowed me to remove proprietary apps running in the background. I won't root again. Rooting worked great in the beginning, then started to degrade. Apps wouldn't run right. Phone got slower. As new apps were developed, they wouldn't run on my rooted phone - etc. Back-ups didn't work properly. Your carrier won't support your rooted phone and rooting voids your warranty.
With Note 2's speed, storage, and battery life - why root? Find an app that does the same but doesn't need root.
All rooting does is give you admin access. It doesn't change the device functionality.
If those things happened to you, it was due to what you did with root, not root itself.
Top reason : Ad Block Plus!
https://play.google.com/store/apps/...wsMSwxLDEsIm9yZy5hZGJsb2NrcGx1cy5hbmRyb2lkIl0.
Except that when you set back to factory, some remnants remained (at least they did in mine).
I suppose if you are a coder and like to spend your days playing with software coding, then you'd want to root.
I like to obtain regular and timely updates for firmware and apps, from their own developers.
If I have to call Verizon for anything, they can't help me if I am rooted.
I want my warranty to work in all scenarios.
So, no root no more for me.
I'm not a coder but I'm rooted with no issues. Having a rooted phone is just like having a desktop OS, if you don't do anything stupid, you won't have problems. All my apps auto-update fine.
Another reason to root is infinite apps in the multi-window list. It makes no sense to deny yourself complete control of your phone.
On another forum I've been assisting with editing apps to use multi-view without root, non-system apps.
That sounds cool, would you be so kind as to post the link?
