Is it possible to disable Dot View?
DILands
Android Expert
I use a magnetic car mount (Primarily because I hate fumbling around with mouths). Any way - now, I have to keep trying to get it on the mount, without the Dot View Screen coming on. I get it - apparently that's how the case operates. If there's any way to disable it, that would be great.
TIA!
Unfortunately there is no way to disable it currently. I am sure it will be a feature available in the future if you are rooted and want to install a custom ROM.
