Sasuke082594
I heard of Xposed Framework being able to do this, but is it possible and worth thr hassle?
Can you explain how to use it or is it common sense? XD i haven't checked it out yet
It must be used with Xposed Framework?
It must be used with the Xposed Framework.
One bug that happens with apps that it will show the error "App Name has stopped working" because you set the DPI too low.
- Open Xposed Installer
- Install/Update whithin the Xposed Installer
- Download App Settings
- Install App Settings with a file manager or an apk installer of your choice
- Enable the App Settings module in the Modules tab of the Xposed Installer
- Soft Reboot
- Open App Settings
- Choose an app
- Application Settings have to be on
- Change the DPI: to any number
- Hit the floppy to save the application settings
- Reopen the app that you chose
Does it work with all apps? I tried witg Minecraft and nothing happened.
Maybe it's because it's located on SDcard and not Internal?
Some games and apps have a set user interface that doesn't change based on DPI.
It turns out it was just the app lol but the rest worked. Which app do I change to lower the DPI for my stock launcher?
