Help Is it possible....
G
GiveMeItNow
Guest
Is it possible to make it so when you hit phone it launch's contacts instead of call log?
If you are rooted, anything is possible.
If you are stock, what you see is what you get.
Then yes, it's possible.
If it's anything like the Hero, the com.htc.resources.apk and the rosie.apk will need to be edited. My advice, check the root sub-forum or check the theme subforum over at XDA.
