So do I, normally, so that's why I was concerned. I wonder if the file size is too large because of the widescreen setting?
Try a #228 first and then reactivate if needed.Yup, I use Handcent and have had no trouble until after (I'm not blaming it...) installing CM7. Since that time, I've been on several ROMs, including stock and rooted .596 and for some reason, my pictures seem to get stuck in the sending mode and sometimes don't send at all. My wife is having the same problem with her D2G. Maybe we're being MMS throttled...lol
last trip we went on was in february to florida, was working after that, but the 228 idea won't harm anything, will try thatTry a #228 first and then reactivate if needed.
Happened a long while ago on a different phone where MMS messages wouldn't send. It has to do with your roaming profile being messed up, or so Verizon tech informed me.
Did you and your wife go on a trip recently? That's what borked mine.
Nope, no change. Will probably be going to big red store to complain, I pay waaaaaay too much each month for four lines to have this happen, thanks anyhow!
Update:
The Wi-Fi experimant didn't make any difference, but removing the multiple "same-name" contacts did the trick. Apparently, when going to CM7 on some devices, if you set up your phone in FroYo, then go to CM7, if you're using Google backup and the SD card to back up contacts, the contacts can get stacked on top of one another. This, combined with doing backups daily on my google account gave me (in some cases) six copies of each contact. I had over a thousand "contacts" in my phone, no wonder it got confused...
