Accessories Is my battery normal?
rsarno
Thank Me, Im Irish!
I know there is a bazillion threads on bad batteries.
I also know my phone is new and needs to be conditioned i guess? I have read the stickies.
I have the seido extended battery, and im at like 4 hours of life, with moderate use.
I made about 20 phone calls, recd about 30 emails, sent maybe 20-30 txts. Browsed FB for a bit, also checked NewsRob for about 20min
I do use Smartkeyboard, also Handcent.
Will it get better? or is this it? I have had my phone for 2 days.
Li-Ion/polymer batteries don't need to be conditioned. Check your phone's up time and awake time. If they're nearly equal, some app is not letting your phone sleep.
Some app is eating your battery juice. I use mine about the same amount as you and I get 24 hours. Today I used mine a good amount reinstalling all my apps and running 802.11n speed tests (upgraded to froyo) and after 10 hours I was at 70%. I've also read those same "bad battery" posts and I just don't see it.
but i barely have any apps
unless it is NewsRob? I notice it takes forever to load my feeds, even though i have it set for 2hr updates it takes like 45min to complete
