PenalColony
Hey guys, forum newbie here.
Here's the situation:
Over the past 3 months or so, my rooted Bionic would occasionally reboot itself at random times. Seemed to happen far more often once I put an extended battery in it.
Once or twice, I could not physically turn it back on. I would get a white light (sometimes blinking, sometimes not) when plugged in via USB. Oddly, the only way it seemed to want to reboot itself was when I plugged it into the car dock. All of this was a minor annoyance at worst.
So, about a week ago, I noticed my nightly Titanium Backup schedule wasn't running correctly. I opened the app and it didn't load correctly, just a blank screen (at this point, the LCD display WAS still on). So I powered down with the power button menu. And that's all she wrote, I have not been able to turn the thing back on in 5 days.
Additional info of note:
-White LED sometimes still comes on when I plug in with USB. It's hugely inconsistent.
-I have three batteries (two standard, one extended) and none of them will hold a charge now, even with an external charger.
-I sent away for a Motorola programming cable, and the phone does not respond AT ALL. Running windows 7 64bit, and when I connect the phone, all it does is make "USB connect/disconnect" toggling sounds for about 40 seconds and stops. Device is clearly not recognized, the computer is calling it a OMAP4430 device, but I have had no luck installing the correct drivers for it yet.
Any advice? I would rather not turn in my phone if it can be fixed, since it is rooted and I'm worried about the aftermath if it's discovered. Any help would be greatly appreciated.
