Root Is My Phone Fixable
jrock4401
I acciedently formated system on cwm recovery and Formatted everything. I was rushing and messed up. anyway i can get to the cwm recovery screen but no backups no data on sd card. nothing. is there any hope for this phone. i tried downloading a stock b09 to computer and transfering files but the only way the pc will read my phone is if i mount usb storage from cwm screen. it just goes to the green guy if turn it on normal. im assuming i erased the rom so theres nothing to turn on. thanks for everyones help
In CWM, mount SD to a computer.
Transfer rooted B09 to SD card.
Unmount SD card.
Format cache, factory reset in CWM.
Go to "Flash ROM from zip" in CWM.
Pick the rooted B09 zip on the SD card.
Enjoy your fixed phone.
wow thats awsome thank yall so much. i went and bought a cheap phone today cuz i thought it was done for. i really really apreciate it
i cant figure this out. i put my sd card in my old phone. i can pull up cwm but off sd card. should i place rom in cwm or just sd in general. i apologize for not knowing to much about this stuff
He may want to put it on the root of the SD CARD and put another in the backup folder inside of the cwm folder. also i have had luck , by unzipping the file and putting copies of that in those two areas. Some roms are different. In clockwork mod you have two directions to go on the first screen backup and recover, and install from SD . I would put some nandroids and the phone wouldn't even recognize them, make sure you have a good internet connection and download a few different ones and try out the working edition of PG's CM10 on Junkies page, just DON'T do what i did and install anything from the BOOST WARP...... complete BRICK, I'm still waiting to see if ZTE can fix it.lol
i wouldnt put it in both, id just read the instructions given with the zip file... and you dont unzip flashables that makes them unflashable
