Root Is my vibrant bricked????? HELP
Okay, so I have rooted my g2 several times before and flashed quite a few custom roms, so i am not new to this. Yesterday I rooted and installed a vanilla android rom onto my samsung vibrant. Then about an two hours ago i factory reset my vibrant, and it went to the vibrant boot screen for about an hour and a half. I then decided to do a battery pull and try to boot into clockworkmod recovery, but i cant to that, it just stays at the boot screen.
I really would like to know if my phone is bricked. Also, if it is bricked would my tmobile insurance replace it? Any help would be much appreciated.
it probably is bricked. and im not sure how it is in the US but here in Poland it clearly says in the warranty that you cant interfere in the OS cause the warranty will be voided. but i think that theres the same thing over there. just use odin to unbrick it and it should all work fine
