cluelessnoob
Hey guys I'm totally new to smart phones in general, as my name would imply, and went with the Optimus V as my first choice.
Anyway to get to the issue, my volume buttons on the right side, the up volume is perfect and fairly easy to press. But the down volume on the other hand is a bit hard to press (although I CAN press it if I push on it hard/directly enough). Now, I found if I take off the battery cover it's just as easily pressed as the up volume.
So the problem lies with the height of the back cover compared to the height of the down volume button I guess? But the down volume button does get quite a bit skinnier. So am I just nitpicking here, should I take it to trade in since I just bought it, or would they all be this way? Thanks in advance for any help!
