is my wallpaper causing most of my batterys drain?
flonkas
So I checked my battery usage and the display used up 74% of the batttery drainage. I'm not sure if my wallpaper caused this or my extensive use of the browser... I'm using city at night live wallpaper with zeam launcher. All answers appreciated
The display, in general, is the most power intensive component of your phone. If you haven't noticed any slowdowns on use I wouldn't worry too much about the live wallpaper.
The battery drain your experiencing is because your phone is not going into sleep mode since the sept. 16th update. Maby people have been experiencing this. Almost any battery app can tell you if this is your peoblem.
Before the update I was getting awesome battery life. Now its horrible and will drain. 2-3% per hour with no use and airplane mode on. They need to fix this problem asap.
