Is she broke
HAT MAN
Member
ok did my searching and read before posting. Had some issues with phone so i did a factory reset
Phone worked great for 2 days and now have 2 issues 1 major 1 minor
major:
Getting 2 hours on ly battery and thats w/o use less then and hour if used.
have killed apps, removed screebl etc no fix
minor: phone will not vibrate foe e-mail or text received but will on calls. All settings are correct.
So what do I do, is phone done or is there a fix?
major:
I cant help you with the first two, but for the third one, go into the market, download an app called "Sound manager"
Launch the app, hit the menu button, go to vibrate settings, and change it to vibrate whenever possible for both of them.
You can uninstall the app afterwards and it wont hurt anything.
Sorry to say but I think your just gonna have to turn it in because it seems like it's giving you wayyy to many problems
anyone know why I cant keep a charge? Please help.
I sure hope I dont have to turn this phone in again.
That sounds more like a battery issue than anything else. Have you thought of buying a new battery? The seidio 1750mah extended battery looks really nice...
And theres a twin pack of 1500mahs with a charging thingy for $12 on amazon.
Id try one of those before you try to exchange it. Because its a power problem....
