flashed thru CWM recovery, cleared cache restarted and didn't work.
Here is the latest and greatest from xda http://db.tt/yn1ot3Y6 just Flashed it so I know it works
How would you go about getting rid of it? Just restore a backup?
That link I posted is the newest from XDA Beats site too. I flashed it and it installed w/o a hitch. Don't know why you are having issues. There is not going to be an icon or anything for it either. If CWM says it installed then it did.![]()
Wet not that it matters but the 3/14 zip is not the latest. The one I posted is the 5.1 zip. Like I said not that it matters. But just incase
I would love to find an EQ that works for this too. I like the Music Volume EQ since I actually get a 5 band slider but with the drivers it FC's on me every time. I love the sound I get with this, but as a musician and a bit of an audiophile I need that EQ to pull the low end out too. Does anyone have an EQ that works with the audio drivers?Oh, my bad. It was the newest 1 on the thread I checked. You probably got yours from a newer thread. No problemo and thanks for the heads up.
I had problems w/ both of them. lol. The one I posted makes my speakers crackle when I adjust the volume. The one that you posted disabled the EQ app that is supposed to work w/ it. I went ahead and installed a backup so I'm not using either right now which kinda sux. lol
I couldn't tell a difference using Beats w/ my Prevail but the Marquee is different. It actually worked and I could tell a slight difference. I wish I could get 1 of them to work. What EQ are you using for the version you posted??![]()
wetbiker i noticed your rom and kernal and the noise you spoke of. i had a noise problem in all music apps at certain times when changing anything. i changed my clock to 1300 and all was fine. i still do it. i had posted this some time ago as a kink in the armor. hope this helps you
Been running the 3/14 version since last week and haven't encountered the popping sound at all, and I'm running the 1.5 hyper kernal at 1400 on performance when I play music. Perhaps just luck? Either way, I swear the 3/14 version just doesn't sound as powerful as the 5/1 version but I can use my EQ with the older one at least so I can't complain![]()
That EQ posted in this thread doesn't work at all! It crashes once you try to execute it.
