is there a benifit going with CyanogenMod over myhero mod?
clandest
current;y using the myhero rom, and I hear only positive feedback about the Cyanenmod and was temteped to try it out, but i don't want to loose everything on the phone.
Thanks.
Thanks.
You will have problems finding the Old style CyanogenMod ROM ... and i would recommend you stay with what you have ,,,,
With the Cyanogen roms (I have the latest "stable" one 4.2.1) you don't "need" to wipe.
You should be able to follow the instructions carefully and have it all be ok.
There have been a few people that have issues after doing it that have had to wipe, but only a few.
I can get you all the cyanogen rom's I saved all them before the whole google thing. I also have 4.2.1 with all the google apps already on it. PM me if you need it.
