Is there a case that fits when using the entended battery?
I have the Droid 3 extended battery which makes the phone just a bit bigger, but means that most cases just don't quite fit properly. Is there a decently priced case out there that does?
I havent tried this with the D3. But with other phones, like the DX, a regular case works with an extended battery IF you dont put the battery door back on the phone. The case actually does a good job of holding the battery in place.
Give it a try. Might work.
If you're going to use a case with the extended battery, then you can use the standard battery cover. Then, all the cases fit :)
Generally speaking, the stock battery cover ALMOST fits the extended battery anyway. It's just a bit tight, and tends to pop off sometimes (unlatch) on one side. However if you put it in a case, the stock cover will stay on just fine. Neall
