When I first got my S3 I tried using LTE On/Off for the Thunderbolt(it worked fine on my Thunderbolt and my Razr and Razr Maxx) and it worked the first day, now when I try to open it it force closes.
I'm looking for a good app myself
I also tried 4G Toggle on the S3 and it doesn't do anything either. It doesn't appear that 4G can be manually shut off on the S3 even through the menus. On a daily basis this isn't an issue for me because I generally keep it on 4G. But sometimes I shut it off if I'm in a non 4g area so my battery doesn't drain.
Don't know of any good toggles, but this app works pretty well https://play.google.com/store/apps/details?id=myc.phone.PhoneInfo&feature=nav_result#?t=W10.
Under Device Information you can change it from "LTE/CDMA?EVDo" which is 4G to CDMA auto (PRL) for 3G
Hope this helps
Will it switch back though? I used that for my Maxx and once I switched to 3g and tried go back to 4g it wouldn't allow me too. I can go in and switch it but nothing changed.
It would be sweet if a developer could make one specifically for the S3, there seems to be a big enough following developer wise.
I just tried it and the phone is able to switch back to 4g from 3g!
Sweet! I'm all over it!
ill try this too. i dont really like using 4G because it kills the battery....3G is enough for me, and wifi
I agree. I use WiFi a lot as well as 3g. I don't care much for 4g due to the battery drain.
I only turn 4g off when I'm in a spotty or no 4g area. Other then that its always on. I can easily get through a full 12hr night at work and still have battery left when I go home, However my part-time job I get no 4g and the battery drains crazy fast so I usually shut the 4g off there so its not searching and killing the battery more then it has to.
