crawdad689
Apologies if this has been covered extensively, but I searched and didn't find anything
How can I make it so that my UI is oriented in landscape mode when I have the kickstand out? I looked in "Scenes" and there seems to be nothing.
Anyone got a fix? Or is the kickstand pretty much only useful when you're watching video or using the landscape desktop clock?
EDIT: While i've got your attention, is there a way to set "power setting themes" so that when my phone is charging, all radios are on, the screen doesn't turn off unless I turn it off manually, and my normal bevy of go-to apps launch? And then when I unplug it, it will automatically go into a more conservative battery mode where certain apps are killed, only 3G is turned on, and the screen turns off after 2 minutes?
Thanks a lot, guys.
-Matt
Thanks a lot, guys.
-Matt
