Is there a one button/click way to turn off ALL sound?
kathayes
On an iPhone there is a hard button switch on the side of the phone to quickly and easily turn off all volume, notifications, etc. on the Note 3 we have to swipe the screen, turn the volume button down, then click on the gear icon to make sure all the notification and media sounds are lowered. Is there an easier way to quickly turn off all volume that may come from the phone?
Thanks in advance!
Settings -> Controls -> (long press) Motions -> Turn Over to Mute
set to "On".
There might be a one button way, but that's instead what I use.
Hold down the power button till the device options menu pops up. There's a sound, vibrate, and mute option on the bottom of the menu along with airplane mode and your power options. Hope this helps!
well,you could get audiomanager Pro and add a widget to homescreen and configure a mute square on the screen,in that way when you have normal and 1 mute its 1 press and every sound can be turned off as long as you have configured in the widget.
