Is there a Productivity lock screen wiget for N4?
chong67
Android Expert
Has anyone seen something like this for the stock N4?
Basically it gives u a summary of things on your lock screen at a glance w/o going into the phone.
None that I've seen. The widgets that work are the stock N4 lock screen are very limited. If you want to customize, WidgetLocker is one of the better solutions.
you mean something like this?
this is useful discovered it yesterday and love it! You can also add Extension like battery info and lots more.
https://play.google.com/store/apps/details?id=net.nurik.roman.dashclock
No, something like your upcoming appointment, miss called, first few line of txt msg, etc.
I think that exactly what it does...
DashClock Update Introduces Calendar Locations, Shortcut to Get More Extensions, and Calendar Visibility – Droid Life
Description
DashClock is a replacement lock screen clock widget for Android 4.2+. It also exposes additional status items called extensions. The widget comes bundled with extensions that give you instant access to:
• Your current local weather
• Missed calls and unread text messages
• Your next calendar appointment
• Unread Gmail inbox or priority inbox conversations
• Your next scheduled alarm
