Root Is there a reboot shortcut in CM 7.1?
JoeSchmoe007
I just switched to CM 7 and find that a lot of things for which I used to use third-party apps are now built-in.
One thing I haven't found yet is a reboot shortcut that I can place on desktop. For now I still use "Quick Boot" from the market that allows to put a shortcut on the desktop to do reboot (other options include shortcuts for shutdown, reboot into recovery and reboot in bootloader).
Is this functionality present in CM 7.1?
Should be a reboot option if you hold the power button down. Don't think there is a way to add a widget for it built into the ROM itself. You would need a third party app like you've been using.
