Sprockethead
Hello everyone. Is there a feature or a check box that I am missing that allows you to turn off the little text labels beneath the application icons on the home screen?
I'm kind of doubtful, but a search did not return an answer. It would certainly clean up the home screen. Plus a lot of labels are "cut off" due to length and that is just annoying.
I am a little OCD. But this MUST have been brought up before or suggested to android dev at some point...
Any advice is appreciated!!
