Help is there a way to turn OFF vibration on the lock screen?
ucla2042
i want to be able to slide to unlock my phone WITHOUT the vibration.
i have gone to settings to disable haptic feedback, but the phone will still vibrate when i slide to unlock.
Download WidgetLocker... Go through the set up process, IE make it default Home and turn off the system lock screen and it works great. It allows you add widgets to your lock screen and modify what your bar does, and many other things.
Mainly, it allows you to specifically turn off the haptic feedback for the unlock swipe. I just double checked and it is very easy to do with this program.
Bonus: It also doesn't lag at all while unlocking!
How do you turn off the system lock screen? I have the droid 2 global... I downloaded widget locker and set it up but sometimes it will have ,
Me unlock widget locker and then go to the original lock screen that vibrates? Is there a way to turn that one off
how do you turn off the system screen lock? i downloaded widget locker and really like it, but it will have me unlock that, and then unlock the regular screen lock, and i don't know how to turn it off
