Is there a way...
Gash
Member
....to disable the software update notification?
I accidentally downloaded JB to the phone (where is it saved to?) but i don't want to install it yet.
The problem is it keeps prompting me to install and the maximum i can postpone it for is 3 hours.
Don't want to have to keep putting it off by delaying it again and again every couple of hours for the next couple of weeks!
Cheers in advance if you can help :)
If you're rooted you can go to system>etc>security and rename the otacerts.zip to otacerts.zip.bak.
That should stop the notification.
If you're not rooted then I don't know of any way to stop it. Someone else may have an idea though.
any particular reason you dont want to update?
