macethedon
a physical numerical keypad? as in;
a physical numerical keypad? as in;![]()
the stock keyboard in 4.2.2 does that for me. From what I recall, 4.2, 4.0 and 2.3 also did.
If yours does not there are a lot of "dialer" apps in the play store.
Sorry, but you got the wrong idea, I meant something like this;![]()
why would anyone prefer T9 over a QWERTY? texting/typing would be a royal PITA doing that. i cannot imagine going back to the timely headaches of tapping out emails via my Nokia 5185i these days.
The predictive text entry plus the physical buttons allowed me to type at nearly 30 wpm, faster than anyone i personally know can do on their touch screen, and with SIGNIFICANTLY fewer errors, because i got familiar with the alternative predictions.
Stuntman: Your link had exactly 1 phone that matched this discussion topic, and I already mentioned it. You sound like a smartass idiot.![]()
Different strokes for different folks, considering that I've been using swiftkey less time than you have but I get higher scores in WPM. Plus the fact that in my case it's impossible for T9 to be faster than Swiftkey because I need dual language input.
I doubt you'll ever find success in your endeavor to look for an Android with alphanumeric. It's just not what MOST people want. The thing with Android is, yes its can be customized fit your own needs, but as a consumer you are still at the mercy of phone manufacturers. Is it possible to have an Android with alphanumeric? Sure. Are they available where you are? Unlikely. Most of the ones on your links are using Japan frequencies which won't work in the US AFAIK. Your best bet would probably be using a soft alphanumeric keypad with T9 prediction. Samsung phones for example, offer a alphanumeric keypad from the settings that uses the same T9 prediction as their nontouch phones. Not sure how good other T9 soft keyboards are in the market.
The search function on the web site was rather limited. The search results of that link was the only searches that I made that had at least one phone that fit your parameters. My intention was that perhaps you could use that web site to do a more exhaustive search. gsmarena.com has a very good list of practially all phones that have been made.
