Is there any S4 physical lock to the car?
spman
Feb 26, 2013
435
27
Is there a Samsung S4 lock to lock the phone to the car, maybe something like Kensington lock for laptop? I want to lock my S4 to the car.
I am a cab driver, and I use S4 for GPS navigation, I want something to secure S4 to the car to prevent theft by the passengers. Thanks
There are the sort of cradles that are used in shops, however I don't know where you'd get one - I'm guessing you'll need to MacGyver something together yourself - just don't secure anything to that infamously femmer Samsung rear panel :D
What are those things that are used in the phone shops to prevent theft called? Those that stick firmly to the back of the phone demo sets in the phone shop to prevent theft
Upvote 0
------>You may want to check Amazon. There are number of such products.
Look into related cattegory and other products for more variety.
  • Like
Reactions: spman
Upvote 0
Since the back of the S4 is removable, I cannot see that this would work very well. On an iPhone (or sadly the S5 if the rumours are true) but not the S4.
  • Like
Reactions: spman
Upvote 0
Could use one of those aluminium frames, and super glue the anti theft to the back cover. The covers are not costly, I wouldn't mind wasting one away. While the aluminium frame, hold it from coming off.
This is the bumper case I have in mind, seem like it would secure the back cover from coming off:
Aluminum Bumper Frame Case for Galaxy S4 i9500 Silver - Galaxys4flipcase.com
  • Like
Reactions: spman
Upvote 0
I hear you, people in this world have sticky fingers and will steal anything and everything. I came up with a few ideas, not sure if they will work.. Just trying to help you brain storm...
Idea #1: A small little 'store display like' stand that I found on amazon, not sure how secure it will be, however i'm sure you can modify it just a little to make it work. Take a look at the links below:
[Aftermarket Product] Brand New Black Anti-Theft Security Telescopic Cell Mobile Phone Display Stand Holder Unit
[Aftermarket Product] Brand New Anti-Theft Security Alarm Charging Display Stand Holder For Mobile Phone Digital Camera
Idea #2: Drill a hole through the side of a case, put some sort of screw-loop with a flush screw head on the inside so the phone still fits inside of the case. Then when there is a loop on the outside of your case you can run a cable like the link I have below through the loop and maybe secure it to your cab. Maybe be a little 'hokey' but i'm sure it would work.
Buggyguard Anti-Theft Retractable Stroller Lock
Idea #3: A secure bag, I'm not sure if this would work because i'm assuming you need to see the screen, but it's a suggestion. A secure bag that is secured to your cab.
Travelon Anti-Theft Lock-Down Pouch
  • Like
Reactions: spman
Upvote 0
Thanks for the ideas.
Idea 1 is not suitable because double side tape is permanently sticked to the back of the phone. I need to remove the phone when I am not driving. Idea 3 also not suitable because I need to see the screen.
Question: For Idea 2, How do you do a "screw-loop with a flush screw head". I get the idea of a flush screw head on the inside of the phone, but how to attach the flush screw head to a screw loop?
Upvote 0
BEST TECH IN 2023
Smartphones
