Root Is this a correct tutrial on temp rooting 2.3 evo shift
Thanks im glad I posted the reply in this forum. I saw the thread you posted in your reply before, only trouble is I dont understand all the terminology incorporated with how to root my shift. I'm looking for a you tube video or a tutorial for simple ppl like myself:)
Well you do need a little knowledge of adb and using linux type cmds. This thread was written for the old root method but it still gives you the basics of adb and sdk Beginner's Guide to Installing the SDK and ADB - Android Forums. If you get that set up and read through the temp root thread (I know it's a lot of pages) you should be able to figure it out. Once you setup adb and get the files in the right folder it's really just copying and pasting commands. I wish I could write a tutorial for noobs but without actually doing the process myself it's a little difficult to do.
Hey man I just apreciate u taking the time out just to point me in the rite direction, big ups for that! I really enjoy every little aspect of pc's n stuff that goes ding n have blinking lights lol I should've took the time out to learn all of this from the inside out years ago smh but Im slowly learning and with help from forums like this I think Ill be nice one day maybe even find an exploit to root a phone one day (wishful thinking):cool:
I hope I'm not out of line for asking. I'm reading the temp root guide for evo shift(2.3) on the xda site and a couple of things got me kinda stuck: It says I have to have adndroid sdk installed on my pc. Thats what I downloaded from the link in your first reply here correct? Ok, My ADB folder? Is that in the SDK I downloaded? Also the ADB directory would be in this folder as well? Lastly,I'm guessing this list of commands I enter when I'm in the adb shell, and after each line do I press enter and continue with the next untill the process is complete? Of course with my phone connected usb.
You aren't out of line. What you need to do to get your phone connected is to install the sdk as per the instructions... The ADB or android debugging bridge is what connects your phone to the pc. You do type the commands into a command prompt and type enter after each one. It has been a long while since I used the adb, and I am a rookie when I use it. I think Crump will chime in here and straighten us both out.. lol
I found this link (it's what I used long ago) to installing the sdk properly and getting all the folders in the right spots.... Hope it helps
Beginner's Guide to Installing the SDK and Getting Started with ADB - xda-developers
All this info is a little bit overwhelming but I think Im getting it! Question, is the ADB folder the actual Android SDK I downloaded and installed? If so where is the ADB directory?
The adb folder is within the android sdk. Go to that folder (it should be named android-sdk-windows) and open it, you will see a folder called tools, and within that is the adb.
But, to be sure you don't need to "run it" it will be used when you get into the adb shell through your cmd prompt....
It means you aren't rooted. Keep trying. This phone has been a pita to root from the beginning for some folks. I have helped a few and it was a lengthy process. Be tenacious and you can get it.
I really hope the devs come up with a good, simple permanent root solution for it soon.
Good info. I followed all the instructions in the guide: Beginner's Guide to Installing the SDK and Getting Started with ADB - xda-developers and every thing worked all the way down to when I was asked to press su for super user and in the cmd window it told me permission denied and had a $ what did I do wrong?
Your getting permissions denied because you don't have root access yet. That's was written for the previous froyo root method (and it assumes you have temp root through visionary) but it's a good start for getting familiar with adb. You need to push the temp root through the new method before you'll gain super user access. I'm definitely still somewhat of a noob when it comes to all the in and outs of adb. If you get stuck somewhere in the temp rooting I would suggest posting in the original thread where people have successfully temp rooted using that method. Unless we have a linux guru here that would like to chime in.. :D
Shoot, I thought he was using the newer 2.3 temproot method...
*inserts foot in mouth*
Ok try this. If you followed the guide to installing sdk and got that setup, that's half the battle. Now go to the temp root thread and download fre3vo. Place the file inside the platform-tools folder in the sdk folder in your C drive.
open windows command prompt
1. cd C:\AndroidSDK\platform-tools
2. adb
Now you should be inside your folder and begin pushing the files. I just tried this and was able to push fre3vo using the first cmd in the temp root thread. Then it should just be a matter of copying and pasting.
But I still think your best bet is to ask questions in the original thread... Since there's people that have succe3ssfully done this.
Just the way he typed it, it looked like he just followed the Beginners Guide and didn't move on to new temp root.
I'm going to leave this here for a day or 2, then move it to the rooting guide so as to help some other folks who may be confuzzled.
Post back with your experience barberboy, whether you can get it rooted or not...
HEY GUYS IT WORKED!!!!!! I followed the instructions crump gave n his last post and it Frickin worked!!! I feel so enlightened I wanna learm more, More, MOOOOOORE!!!! (in my pinky ant the brain voice) All you guys are so much help man I love this forum Im down4life!
Crump is an asset here. He has helped me numerous times.
I'm glad you got yourself temp-rooted, and thanks for updating the thread as well.;)
yeeeeeeeeeah crump's the "ish" lol as well as you to bro. You got me started in the rite direction Big Ups!:cool: Now Ill just wait for the revolutionary site to add the shift to there list and then im going to S off and NEVER update my device again unless the pros in these forums green light it.
Haha.. Glad you got temp root. Hopefully it won't be too long before perma root is available and you can start hacking away.
That's not for the Gingerbread update, that actually doesn't even look right for rooting Froyo. Follow this link for temp root if you took the Gingerbread update Working EVO Shift Temp Root for 2.3.3 Newst OTA [8/04/2011] - xda-developers
Don't make replies and statements to things you didn't know. crump, or what ever you are, did you ever did the tutorial by yourself? how could you know by just looking at that link that it is wrong.
For your information, I have done the steps and I have rooted my EVO Shift without any issues.
Next time when you comment on something, be sure that you have some practical knowledge on that issue.
Lol.. you sure did take my post personal. If I was wrong in my statement then I apologize, but you won't convince me that you used that method to root your Shift if it was running Gingerbread... which the original poster is. If it rooted froyo, more power to you. I pointed the original poster in a different direction because it is a known Gingerbread temp root method and comes from a more than credible website. BTW, glad you decided to post in the forum.. even it was just to flame me :rolleyes:
