So I've been playing around with my new Fascinate, and noticed something odd.
Whenever I plug the phone in to charge it, the battery jumps up about 20%(at least, according to apps like Battery Left and Battery Widget). I was wondering if anyone else has experienced this. Is it just a bug in the apps(my initial thought) that increases the battery percentage when plugged in? Or is it something to do with the battery itself?
Also, I'm curious if the battery life I'm getting is normal. The battery seems to last about 3.5 to 5 hours(depending on use) of actual use with brightness turned down to the minimum, managing 3g/wifi, and no apps syncing AFAIK. From what I've read that sounds about normal, but I'm not entirely sure.
I'd appreciate any help.
