1. Does iSnapMe work with Android phones?
Although iSnapMe was originally designed for the iPhone, it does work with selected Android phones. Motorola Droid Model A855 has been tested and is fully compatible with iSnapMe. Droix X has also been tested but you can only expect about 50-75% of the image to be filled.
To me that doesn't sound like it would be worth it, especially if there are little reviews. Hope that helps, that is from there website btw.
