Root issue with booting after rooting and doing app2sd method
hello.
I just rooted my phone using this method.
forum.xda-developers.com/showthread.php?t=724741
after that I installed this rom
http://forum.xda-developers.com/showthread.php?t=675957
after that I did the app2sd method and that's where my issue started.
basically followed it step by step and now my phone just sits at HTC quietly brilliant and every 30 seconds it goes black and back to the white screen
any thoughts?
Well, the ROM link you gave just goes to the list of known ROMS, but I'd say do a battery pull, boot to recovery restore your last nand back up, wipe and reflash.
ok change link
I have repaired partion on SD card. reflashed and nothing. I didnt back up the nand, i think that might be a huge issue
ok change link
Did you back up the data on your sd card before you did this, or is there anything you want to save on it? It sounds like the partition got messed up. You may end up having to reformat your card and reflash after that.
something on your sd card isn't partitioned correctly. until you get that going you're going to be stuck in a boot loop. make sure you partition the correct ext for your rom
ok its up and runing. battery is low maybe thats why it didnt like me
not sure what i did. But when im awake in the morning i will try the app2sd thing again. thanks for the inputs tho.
